[ICEM] Volume orientations problem on first cells boundary layer |
September 7, 2019, 04:13 |
Rep Power: 7 |
I have a problem with ICEM. I meshed a semi-wing and the first cell height is 6e-6 in order to have y+ = 1. The problem is that when I set this distance and check the mesh I found some volume orientations problems only in the root section which is adjacent to the simmetry wall. It's quite strage because I don't see any problem in other sections. If I change the first cell height only in the root section and increase to 1.2e-5 the problem disappears. Can someone help me? These are the links of the images: https://ibb.co/nnNzfWx https://ibb.co/mv6Fq2p |
October 4, 2019, 14:07 |
Gwenael H.
Rep Power: 20 |
If you have some issues with the mesh normals you can use the reorient mesh tool in ICEM under > Edit Mesh > Reorient Mesh > Reorient Volume > apply This should do the trick. Have fun |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
