[ICEM] 3D wing tip
Old   May 2, 2009, 03:36
Default [ICEM] 3D wing tip
realanony87 is on a distinguished road
I am using ICEM hexa to model a 3D wing with a Naca 0006 profile attached to a wall. I am wondering what kind of blocking structure is suitable for the wing tip.
An O-grid works fine for the Wing section near the wall, as that resembles a 2D construction, but at the tip, it is not so clean. I get relatively low quality (0.2) and very low angles (4).
I have basically put an O-grid around the whole wing, Also I am not using degenerate blocking, so the trailing edge is modelled as a thin flat edge
Thanks.
realanony87 is offline   Reply With Quote
Old   May 3, 2009, 14:34
Default Extend the topology...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You could have the ogrid structure extend out past the wing tip and thru to the far field...
Just imagine that the wing cross section topology extends from the root, past the tip and all the way to the far field... Except that between the root and the tip, the wing material is solid (or VORFN) and the volume between the tip and the Far field is fluid (or Live)...
Of course, once it pases the wing tip, you can fan it out and square it up for quality.
This is assuming you have a flat wing tip.
PSYMN is offline   Reply With Quote
Old   April 24, 2010, 12:15
Ke peng
kepeng is on a distinguished road
Your suggestions is very good. BUT, if the trailing edge is modelled as a line with zero thickness, how to deal such condition? The mesh at the leading or trailing edge sides could be meshed in the manner of airfoil, and the mesh at the wing roots or tips side, could use just a simple O-grid, then but how to combine those mesh together?
kepeng is offline   Reply With Quote
Old   November 6, 2019, 13:34
Aideal Zohary
AidealZohary is on a distinguished road
Anyone knows on how to use this approach with a semi bullet shaped domain? or is a rectangular domain is the only viable farfield for this method?
AidealZohary is offline   Reply With Quote
3D Wing Analysis Ed FLUENT 5 April 13, 2019 13:07
Forward swept wing simulation abid Siemens 1 June 16, 2012 13:26
How to model vortex of supersonic wing tip Bernard FLUENT 0 January 29, 2007 03:20
Wing tip vortices using Fluent Jainy FLUENT 3 August 22, 2005 19:13
Delta Wing Structured Grid Riaan FLUENT 3 December 31, 2004 12:03
