[ICEM] Angle below 18 degrees solution?
Old   November 17, 2019, 23:25
Default Angle below 18 degrees solution?
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
hi,
I was meshing a bottle shown in Fig. 11.11.png I had used O-grid 12.png13.PNG. I am getting angle below 18 degrees mostly at the bottleneck14.PNG15.PNG. Kindly suggest some solution.
regards
rupak504 is offline   Reply With Quote
Old   November 18, 2019, 01:25
M
AtoHM is on a distinguished road
Would it not be easier to create a 2d-mesh and extrude/rotate it about the axis?
AtoHM is offline   Reply With Quote
Old   November 18, 2019, 01:39
rupak504's Avatar
Lolita
That's one way to do it, but i wonder, would that solve the problem. Anyway i will try that first and see.
Old   November 18, 2019, 03:10
M
I never tried it because my geometries are usually not symmetrical, but with this I would definitely try. I would be curious to see your results there.
Old   November 19, 2019, 06:51
Sebastian Engel
bluebase will become famous soon enough
Please create a screenshot of the cross section
Use "scan planes" to create a section and show us the corner region in more detail.
You'll find scan planes in the context menu of premesh.
bluebase is offline   Reply With Quote
[snappyHexMesh] No generation of layer onto zerothickness surface crubio.abujas OpenFOAM Meshing & Mesh Conversion 3 October 25, 2022 03:20
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 10:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
