-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Imported Data will not be compatible (https://www.cfd-online.com/Forums/ansys-meshing/222630-imported-data-will-not-compatible.html)
theEVguy December 2, 2019 12:40
Hello Folks! Need Some Help here!
I am currently working on CFD model for a motor and study a thermal behavior inside the motor pack. I am currently finished working on the mesh design of the motor and trying to import my data in Fluent but I am having an error which says as follows:
imported data will not be compatible with the data coming from the Mesh cell. Do you wish to delete the upstream cells/data from the system and replace the case with the imported file?
FYI, I have saved my mesh file in two different formats under same name in .msh file and .meshdat file
