[ANSYS Meshing] Meshing Element size
Old   March 15, 2020, 16:56
Default Meshing Element size
Muhammad Rizwan
rizwan4081 is on a distinguished road
Greetings.
I am new to Ansys Fluent. I am doing an analysis where I am analyzing the flow over a car in a tunnel. I have the Student version of the software with a limitation on the number of mesh elements of a max being 512000 cells. I would like to know how to calculate the minimum element size of the mesh?
The tunnel is 500 meters and by default the mesh element size is 25 meters, But I want to know if there is a way to calculate a minimum size so as to guarantee the convergence of solution?
rizwan4081 is offline   Reply With Quote
Old   March 17, 2020, 14:28
fluidus is on a distinguished road
Hi there,
I am no expert but some things come to mind:
-I think one of the key issues to reach convergence is to properly capture the boundary layer. How precisely do you want to capture it on the car surface? Depending on this you should set a minimum height to reach certain y+ values (https://www.cfd-online.com/Wiki/Dime...stance_(y_plus)). Ideally you should also capture it on the tunnel walls, but due to your limitation I think you should save some cells there.
-In my case it helps to divide your overall volume into smaller "boxes" and force the elements with Edge Sizing and increase the size as you get farther from the car.
-I don't know what mesher you are using. But if you are using Ansys Meshing you have some global parameters (under "Sizing") to play with. The ones I usually modify the most are the minimum size of element and face and the growth rate.
Finally, I think this reference would be really useful in your case: https://repository.lboro.ac.uk/artic...-0590_/9230000
It includes very detailed experimental data together with CAD model so you can validate your model.
I hope it helps.
fluidus is offline   Reply With Quote
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
Solution diverge with small element size. stone123 FLUENT 4 October 26, 2013 05:48
[ICEM] Global Element Seed Size? Tetra meshing issues info_bahaider ANSYS Meshing & Geometry 0 November 28, 2011 08:12
[ICEM] Meshing Size Problem eRzBeNgEl ANSYS Meshing & Geometry 2 April 17, 2011 15:53
