[ANSYS Meshing] Reducing mesh size along z-axis for 3D conjugate heat transfer problem |
May 9, 2020, 13:02 |
Anthony
Rep Power: 5 |
Hi everyone
I am attempting to model a single fin of a heat sink, surrounded by air, as a conjugate heat transfer problem. As it is only a single fin, my domain is much larger in the x and y directions than it is in the z. My problem is that I cannot get a fine enough mesh size in the z-direction to capture the boundary layer without making my entire mesh tiny, which I cannot really afford to do. I have tried using edge sizing with hard behavior, with multizone, tetrehedral and even hex-dominant methods, but the size doesn't permeate through the whole domain. If I use inflation, ANSYS I can't the overall thickness to what I need it to be. Is there a setting I am missing or is this approach completely inappropriate? I can upload a picture of the domain if it will help. Cheers! |
May 9, 2020, 15:50 |
M
Rep Power: 12 |
Go ahead with that image
May 9, 2020, 22:55 |
Anthony
Rep Power: 5 |
May 10, 2020, 02:51 |
Domain
Anthony
Rep Power: 5 |
It appears that my previous reply didn't link the image properly, hopefully this works, thanks |
meshing, refinement |
Using Ansys mesh for foamextend conjugate heat transfer | rsa | OpenFOAM Pre-Processing | 2 | February 5, 2020 04:29 |
Mesh for conjugate heat transfer problem from ICEM CFD | Lokanayaki | SU2 | 1 | September 18, 2018 04:25 |
Problem with conjugate heat transfer in Fluent | JianT88 | FLUENT | 0 | March 16, 2015 08:17 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
