[Other] Double Ended Magneto-Rheological Fluid damper with shaft bypass |
May 13, 2020, 12:09 |
Ahammed Rubel
Dear Altruists,
I want to simulate double ended MR damper with a shaft bypass. I mean a piston will give a reciprocating motion inside a cylinder with full of MR Fluid. There are a number of slot at outside of shaft where piston mounted. Fluid will pass one side to another during reciprocating motion of piston. I have attached a free hand concept here. Anyone can help me how can I generate geometry for my Damper model. Thanks in advance. Rubel Ahammed |
May 16, 2020, 08:47 |
#2 | |
mCiFlDk
Rep Power: 6 |
What do you need exactly? Because "generate the geometry" is a quite wide concept I don't know if you're referring to generate the geometry by using ANSYS (Spaceclaim, ICEM, etc) or using a commercial CAD... Don't get you. Regards |
July 13, 2020, 01:15 |
Rubel Ahammed
Rep Power: 6 |
Dear Experts,
Here I have done my geometry by using space claim. Actually I want to do a sinusoidal motion of a piston inside a cylinder. Cylinder is occupied by a magneto-rheological fluid. Inside of piston have two passage for passing fluid one side to another. During reciprocating motion fluid will pass from one side to another. I have attached picture here for my geometry and mesh. When i run my simulation an error occur after completing 1-2 iterations. | ERROR #002100004 has occurred in subroutine Out_Scales_Flu. | | Message: | | The Reynolds number is outside of the range expected based on the | | Option selected for the TURBULENCE MODEL. Check this setting, | | the values of the properties, mesh scale, consistency of units | | and solution values in the input file. Execution will proceed. How can I solve this problem. Thanks in advance With Regards Rubel |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Shaft rotating in fluid CHT | Jonny6001 | STAR-CCM+ | 0 | May 26, 2013 18:16 |
