[ICEM] Quarter O-Grids and Quality Issues
Like Tree3Likes
  • 1 Post By bluebase
  • 1 Post By AtoHM
Old   May 14, 2020, 15:35
Default Quarter O-Grids and Quality Issues
aunmhd is on a distinguished road
Dear ICEM Community,
I have a geometry comprising of a conical body in ICEM CFD. The geometry itself is pretty complex comprising of propeller blades mounted on a streamline body comprised of two cones. The overall quality metric (minimum) of the Pre-Mesh is 0.2 (I'm trying to improve this further a bit). The Determinant (3x3x3) of the Pre-Mesh however is giving me negative values only in one of the 6 Quarter O-Grids I have made around the conical tips in the front and back cones. Can somebody comment on why this is such and what I may do to fix this?
aunmhd is offline   Reply With Quote
Old   May 15, 2020, 13:38
Sebastian Engel
bluebase will become famous soon enough
Hi aunmhd,
it seems a few blocks might became inverted, because there isn't any element with a determinant close to zero.
there is a feature called "fix inverted blocks" you may try it a few times and see whether it fixed it.
aunmhd likes this.
bluebase is offline   Reply With Quote
Old   May 15, 2020, 16:50
Lightbulb
Thanks bluebase,
The problem seemed to be originating from inverting blocks as you correctly pointed out. I was able to fix this issue by the 'Invert Selected Blocks' feature only selecting the blocks of the O-Grid. Using 'Fix Inverted Blocks' fixes the problem in the O-Grid but also inverts other blocks elsewhere in the domain which were otherwise properly 'aligned'. This continues in an endless loop where blocks are inverted rather randomly in the domain.
While we are on this could you please elaborate what is the significance of this quality metric determinant 3x3x3 and what minimum value is acceptable for solvers in general.
Thanks.
Old   May 16, 2020, 04:51
M
AtoHM is on a distinguished road
Determinant 3x3x3
aunmhd likes this.
AtoHM is offline   Reply With Quote
Old   July 27, 2020, 13:24
Originally Posted by bluebase View Post
Hi aunmhd,
Hey,
I require a boundary layer around my geometry (shown in red, blue and green).
If I create the Quarter O-Grids first and then try to create an O-Grid around the blocks, ICEM gives me an error.
I worked the other way around. Created an O-Grid around the blocks (boundary layer) and then created Quarter O-Grids. Although this did resolve the problem somewhat, however, it gives rise to elements with very poor hex element aspect ratios in the boundary layer.
Can you suggest how this issue may be fixed?
Old   July 31, 2020, 11:56
Sebastian Engel
Well, high aspect ratios in boundary layers is not inherently bad. It's important that the gradients are properly resolved. If the longest side is in flow direction in which gradients are small, then there is no problem. The large gradients normal to the surface are the ones you need to resolve, aren't they?
Regarding poor element, i can only give general recommendations: use the tools available!
Use quality histograms, and "scan plane" to study where those bad elements occur and why.
Try to figure out a way to make those bad elements into square boxes again.
This can be a lot of tedious work which hardly can be solved via a few written sentences...
Old   August 3, 2020, 01:04
Thank you for your reply.
The bad elements that I am unable to resolve are not a result of my blocking strategy. I have been careful with the angles. The problem arises when I add boundary layers to my model. I modelled the geometry in CATIA and upon import the algorithm applied to the surface transfer 'changes' the surfaces especially around the region where the propeller is attached to the spinner. The cell height based on y+ calculations is 1.4e-5 m. Once inflation layers are added, it gives rise to poor quality elements because of the surface quality. I tried modelling the spinner in ICEM but when I trim the surface with the curve at the propeller base, the problem persists. I export the geometry as .model file into CATIA.
Is there any way I can resolve this issue?
I have attached a photograph which shows part of the inflation layers and the 'smudged elements'.
Old   August 3, 2020, 11:34
Sebastian Engel
I don't know exactly.
I think some imported surface might be triangulated internally. And 1e-5 is quite close to the default triangulation tolerance. Can you try to decrease (put a smaller value) the topology tolerance as well as the triangulation tolerance? At least two magnitudes smaller than your smallest characteristic length, so at least 1e-7.
You can find it somewhere in the settings, i think it is in the general options tab.
Then remesh.
Did that help?
aunmhd likes this.
Old   August 3, 2020, 22:44
Smile
Then remesh.
Did that help?
The tolerance value can be edited while importing the geometry from CATIA. Like you suggested, I decreased the value to 1e-7. And . . . it works like a charm!
Thanks a million bluebase. Can't thank you enough. Cheers!
icem 14.0
Adjusting fvsoluion and fvschems based on the mesh quality! tareqkh OpenFOAM Running, Solving & CFD 2 October 17, 2017 12:42
[ICEM] ICEM 'Volume Change' Pre-Mesh Quality function disapears in version 15.0 Anna Tian ANSYS Meshing & Geometry 1 August 13, 2014 10:30
[ICEM] Mixed Grids papis ANSYS Meshing & Geometry 0 July 24, 2014 08:27
[ICEM] how to improve mesh quality around sharp edge? foolboy007 ANSYS Meshing & Geometry 1 January 23, 2013 11:57
comparing different models and grids Philipp Main CFD Forum 4 August 31, 2001 04:14
