[TurboGrid] Differing Layer Topology Causes Negative Volume Cells
Old   May 14, 2020, 17:05
Default Differing Layer Topology Causes Negative Volume Cells
Tate
t8fanning is on a distinguished road
I'm trying to generate a mesh for a centrifugal compressor with a main and splitter blade. I've done it before with very similar geometry and no problems. However, this time, I'm having an issue where the topology for layers above a span of 62.5% cross each other and cause negative volume cells.
This only happens when I attempt to mesh the main and splitter blades. When I use only the main or only the splitter no topology problems present.
I have not been able to find a way to edit the topology control points with Turbogrid 17.2. Does anyone have any ideas how to fix the problematic layers?
Some pictures of the layer topologies follow.
Hub:
37.5% span:
75% span:
Shroud:
t8fanning is offline   Reply With Quote
Old   May 14, 2020, 17:43
Tate
After fiddling around with the order in which I generated the export points feature from designmodeler, I've found some interesting points.
Turbogrid created a consistent topology for each layer only when the export points feature got the blade info from the flow path and I manually entered the blade surfaces. However, once I changed anything else in Turbogrid, topology changed and was poor. When I tried to give export points blade info from the blade feature, it created poor topology.
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 10:11
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
how to set periodic boundary conditions Ganesh FLUENT 14 November 26, 2018 11:26
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 14:43
Negative volume cells nbons STAR-CCM+ 2 January 27, 2015 12:18
