[Other] Import airfoil SpaceClaim
Like Tree1Likes
  • 1 Post By FJSJ
Old   November 8, 2013, 09:09
Default Import airfoil SpaceClaim
Michael
myaero is on a distinguished road
Hello everyone!
I started working on Workbench a few days ago and my goal is to analyze an airfoil.
So my first step is to load the airfoil coordinates in SpaceClaim (I do not have DesignModeler). But it does not work. I have read many explanations on how to do it on the internet and they are all very clear. However it does not work, even though I am using (I think!) the proper format.
So I started investigating and I tried with only a few points of my airfoil. Here is my file:
3d=false
polyline=false
0,0 0,0
1,45291 2,033
2,08771 2,40706
2,83441 2,76827
3,69127 3,11559
4,65628 3,44792
5,7272 3,76414
The result is in the attached picture. I read the coordinates of the points and I have the feeling that SpaceClaim separates the figures through the commas. For example, one of my points has the coordinates (7272; 7641) which really looks like the last line of code...
(btw I also tried adding a "1" at the beginning of everyline to say that it is the curve number 1, but in this case, SpaceClaim would not even read the file and find an error instead at line 1)
Are you familiar with this problem? Your help is much appreciated
myaero is offline   Reply With Quote
Old   November 4, 2015, 06:42
Javi
FJSJ is on a distinguished road
Hi All,
just in case anyone needs it:
http://cao.etudes.ecp.fr/spaceclaim/SC_airfoil.pdf
It shows how to prepare the point data file
gaza likes this.
FJSJ is offline   Reply With Quote
Old   April 24, 2018, 23:18
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Originally Posted by FJSJ View Post
Hi All,
The link is dead. can you resend the new link?
Thank you
Best Regards
Teguh
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   May 13, 2020, 08:34
Przemek
gaza is on a distinguished road
http://cao.centralesupelec.fr/spaceclaim/SC_airfoil.pdf
best regards
pblasiak
gaza is offline   Reply With Quote
Old   May 16, 2020, 08:52
mCiFlDk's Avatar
mCiFlDk
mCiFlDk is on a distinguished road
Thank you
Best Regards
Teguh
Hi teguhtf,
I think you're importing points without indicating ANSYS which values Z axis have. It's a common mistake when importing points from any .dat to several CAD programs.
Regards
mCiFlDk is offline   Reply With Quote
airfoil, coordinates, load, spaceclaim
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
Creat or Import 2D airfoil profile. Jackie FLUENT 14 May 11, 2013 06:16
Import an airfoil to ANSYS workbench NAJEM FLUENT 0 November 3, 2009 14:12
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
