[ICEM] meshing
Old   May 17, 2020, 22:02
Default meshing
shohag
shohag is on a distinguished road
i am meshing hydrocyclone. due to ogrid block,at the center all the edges take nodes of parallel edges which are at the wall of the body. so at the center, mesh is very fine. but i need coarse mesh at the center. how can i do this? can anyone help?
shohag is offline   Reply With Quote
Old   May 18, 2020, 04:20
Sebastian Engel
bluebase will become famous soon enough
Hi shohag,
you can either use different refinement levels or a special blocking strategy called "nesting" in order to reduce the mesh density in the center.
See the following link to get an idea:
Is there a way to coarsen only a part of interior Hexa elements?
bluebase is offline   Reply With Quote
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
