[ANSYS Meshing] Coarse Mesh to Fine Mesh outpu(.dat) transfer
Like Tree2Likes
  • 1 Post By Gweher
  • 1 Post By Gweher
Old   July 2, 2020, 14:08
Default Coarse Mesh to Fine Mesh outpu(.dat) transfer
steadyman is on a distinguished road
Hello everyone
I performed a successful CFD analysis with fine mesh(in FLUENT). However, I have to transfer output(.dat etc) of that analysis to a different mesh (same geometry but coarser mesh).
How can I perform this transfer by using ANSYS ?
steadyman is offline   Reply With Quote
Old   July 6, 2020, 01:43
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Well if you want to use the results to perform another analysis, say structural deformation from fluid loads you can use the data mapping inside of Workbench.
Have fun
steadyman likes this.
Gweher is offline   Reply With Quote
Old   July 6, 2020, 01:56
Originally Posted by Gweher View Post
Have fun
Actually I want to map this fine mesh results to coarse mesh.It is not for another analysis.Just mapping
Old   July 6, 2020, 02:59
Gweher's Avatar
Gwenael H.
Ok well if it's just for "visualisation purpose" you could either use an external data in conjunction with a simple model setup and import the field of interest to plot it on the coarser mesh.
Or if you have access to Ansys Ensight post processing tool there is also a way to map it there. Alternatively it should also be possible using paraview. You just need to export your fluent data first to the proper format (*.encas file), same with the coarse mesh. Or you could eventually use the plot csv extension (ansys appstore), to plot it on geometries / meshes.
Have fun
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
[ICEM] Transition layers from quad (or hexa) coarse mesh to quad (or hexa) fine mesh? macfly ANSYS Meshing & Geometry 4 February 10, 2014 06:09
[GAMBIT] How to mesh a cylinder with fine to coarse cells Bharatt ANSYS Meshing & Geometry 3 August 12, 2013 00:45
fine mesh ==> coarse mesh Mahbub Siemens 3 October 11, 2003 01:19
