November 12, 2022, 02:01 |
connection
Zese
Rep Power: 12 |
Dear all
I have a poblem with connection in ansys meshing. I have a complex geometry whose solidworks file was not modified so I had to define different fluid zones part by part. the following you can see them. now I tried two methods: 1. I meshed each zone separately and import them to cfx. 2. I combined them in geom and then import all for meshing. the problem is that the neither ansys meshing nor cfx can generate connections automatically which made me suspicious whether the zones are connected or not. In the past with other geometries the connections could be created automatically. How I can be sure about it? |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
"License server connection lost" error | curious_ssl | FLUENT | 0 | February 10, 2010 06:27 |
One to one connection for periodic faces | Al | CFX | 0 | August 29, 2007 02:34 |
