[ICEM] problems about face mesh missing elements
Like Tree1Likes
  • 1 Post By lbj007
Old   June 20, 2020, 07:46
Default problems about face mesh missing elements
lbj007 is on a distinguished road
Hi, I'm meshing for a 10-cell fuel cell stack, first I generate face mesh using blocks,then I can get the mesh in the middle by extruding mesh to form the 1-cell mesh and translating and coping mesh,and I need to get the mass flow of each stack.,so I create some iso-surfaces parallel to outlet,but I find there are some elements missing on the face and I'm confused. This will lead to inaccurate mass flow calculation.Does anyone know how it works?
ramakant likes this.
lbj007 is offline   Reply With Quote
Old   June 22, 2020, 06:58
solved,I think it's some of Fluent's bug,I tried today and it no longer occurs
Old   June 22, 2020, 07:23
Gert-Jan
Gert-Jan will become famous soon enough
I don't know if this helps, but when I see something like this in ICEM, mostly the problems are related to the normal of surface elements not being consistent. You can change this in the edit Mesh Menu > Reorient Mesh > Reorient consistent.
Just select one of the elements as a reference. It does not matter which one. In the end, at least all elements for each boundary have the same normal and are in one group in Fluent.
Gert-Jan is offline   Reply With Quote
Old   June 22, 2020, 10:02
Thanks first, you give me a helpful 'trick',but my model doesn't need to consider about it,I just use blocks to generate 1-cell's mesh and copy-translate it 9 times.
still thanks for giving a idea.
meshing, missing cells
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
