philip lu
Rep Power: 5 ![]() |
hello,
I reedited my thread: I'm new in ICEM. Basing on a 2D planar block I want to create a 3D block using "2D to 3D" under blocking 1. but only "translate" worked out and more over 2. after defining the node number in edges of the newly created 3D block, the mesh can only be generated in the original 2D face, along the newly generated direction, nothing sure, I'm not familiar with ICEM yet, so does someone know, where is the problem? thank you in advance Last edited by philiplu; June 25, 2020 at 14:59. |
Gwenael H.
Rep Power: 18 ![]() |
Hello Philip,
The option you're using is allowing you to create a 3D blocking. The blocking needs to be associated to "support" geometry. As you didn't create the 3D geometry your 3D blocking will be associated with a 2D geometry. Have fun ![]() |
philip lu
hello, Gweher,
thanx indeed for your reply. sure, I've fun and you too. regards, thanks |
Display Modes | |
[ICEM] HAWT - Problem making block follow curved face | Shrap | ANSYS Meshing & Geometry | 10 | February 12, 2020 12:47 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 11:26 |
[ICEM] Problem of merger of block corner points. | Korayabi90 | ANSYS Meshing & Geometry | 1 | February 13, 2017 15:16 |
[blockMesh] Wedge-shaped block: Problem with skew faces | Reni | OpenFOAM Meshing & Mesh Conversion | 2 | October 28, 2014 13:53 |
3D T-rex: Problem Initializing Block | Zip | Pointwise & Gridgen | 3 | September 9, 2014 13:39 |
