-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Coarse Mesh to Fine Mesh outpu(.dat) transfer (https://www.cfd-online.com/Forums/ansys-meshing/228471-coarse-mesh-fine-mesh-outpu-dat-transfer.html)
steadyman July 2, 2020 14:08
Hello everyone
I performed a successful CFD analysis with fine mesh(in FLUENT). However, I have to transfer output(.dat etc) of that analysis to a different mesh (same geometry but coarser mesh).
How can I perform this transfer by using ANSYS ?
Gweher July 6, 2020 01:43
Well if you want to use the results to perform another analysis, say structural deformation from fluid loads you can use the data mapping inside of Workbench.
Have fun ;)
steadyman July 6, 2020 01:56
Originally Posted by Gweher (Post 776939)
Have fun ;)
Actually I want to map this fine mesh results to coarse mesh.It is not for another analysis.Just mapping
Gweher July 6, 2020 02:59
Ok well if it's just for "visualisation purpose" you could either use an external data in conjunction with a simple model setup and import the field of interest to plot it on the coarser mesh.
Or if you have access to Ansys Ensight post processing tool there is also a way to map it there. Alternatively it should also be possible using paraview. You just need to export your fluent data first to the proper format (*.encas file), same with the coarse mesh. Or you could eventually use the plot csv extension (ansys appstore), to plot it on geometries / meshes.
Have fun ;)
