[ICEM] Some surfaces are not cut ('segment by plane') [+ image] |
Rep Power: 4 ![]() |
Hi all,
My problem is described by the image, please ask if not clear. Why are some of the the surfaces not cut as I expect? Thanks https://ibb.co/j8rNSzx |
Henrique Stel
Rep Power: 15 ![]() |
Please attach the image within the question. Most people won't click on links, for obvious reasons.
Anyway, before seeing the image itself: did you try to project a line on the surface before trying to segment it? The segment by plane feature usually doesn't work fine. |
#3 | |
Yes I tried that too, and increasing tri tolerance, and making from 2-4 curves/multiple curves, and other things. In the end I had no more time to waste on ICEMs segment 'tools' and hand made my surface again from lines. Erm I'm not sure how to add an image, let's see if this works: Ok it works but some other images dont, is it an image host problem? ![]() |
Display Modes | |
[Gmsh] Patches in GmshToFoam | hannes | OpenFOAM Meshing & Mesh Conversion | 11 | March 8, 2013 09:01 |
Plotting Residuals | ata | OpenFOAM | 12 | July 8, 2011 03:50 |
Periodic cut surfaces - ICEM? | Jane | CFX | 0 | May 18, 2008 21:55 |
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position | zhoubinwx | ParaView | 3 | February 13, 2008 05:46 |
cut plane? | qiaomu | FLUENT | 1 | May 12, 2003 18:24 |
