[ICEM] CGNS mesh modification through ICEM
Old   January 29, 2021, 13:16
Default CGNS mesh modification through ICEM
rbalmer
rbalmer97 is on a distinguished road
I am new to CFD and I'm looking to duplicate my mesh by mirroring about the x-axis. I am running simulations in SU2 which to my knowledge only supports .su2 and .cgns mesh files. I have a .cgns mesh file that I'm looking to modify in ICEM.
I imported the .cgns file to ICEM where I have then mirrored the mesh, although I am not clear on how to export it back out as a CGNS file suited for SU2.
I would appreciate some help on this matter which I appreciate is maybe quite trivial, I'm still learning my way through CFD.
Many thanks
Royce
rbalmer97 is offline   Reply With Quote
Old   January 29, 2021, 14:03
Kira
aero_head is on a distinguished road
Hello Royce,
Select the 'Output Mesh' tab at the top -> select the 'Select Solver' option (it's the red toolbox) -> Output Solver (hit the drop down arrow): CGNS
The go to Write Input (still in Output Mesh tab, last one on the right), select any scaling and/or other options and the click Done. Will save your file as a .cgns.
aero_head is offline   Reply With Quote
Old   January 31, 2021, 15:52
rbalmer
Thank you very much for your help!
cgns, export, icem, mesh, su2
[ICEM] CGNS Mesh Importation into ICEM huey1080 ANSYS Meshing & Geometry 5 April 3, 2022 18:19
Issues with CGNS formatted mesh in SU2 jlwhelan28 SU2 5 February 13, 2017 11:48
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 21:41
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
