[ANSYS Meshing] perforated plate in a channel |
December 14, 2020, 16:06 |
ali akbar salehi
Rep Power: 5 |
Hello everybody.
I'm new to fluent and I have some problems in ansys meshing with a perforated jet plate in a channel .I want to evaluate heat transfer of my working fluid (air) in a channel (air heater) and I use jet plate impingement on a heated surface(absorber).I used boolean operation and substracted the perforaed plate and I preserved It. After that in ansys meshing I enter contact manually but it takes a long time and I recieved the error that some of your surace aren't in appropriate direction but when I didn't do it manually ,I 'v got problems in taking all the surfaces (surface in the holes that have interface with fluid domain) and in fluent I have problems in coupling interface couplings.I attached my geometry images. Thanks in advance. preview1.png preview.png |
ansys fluent, ansys meshing, perforated plate |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
Finding Drag Force from Skin Friction | Rob Wilk | Main CFD Forum | 0 | May 8, 2020 06:04 |
Perforated plate | franzdrs | Main CFD Forum | 16 | November 12, 2017 05:48 |
Need help on perforated plate with less than 2% open area | sosososo1114 | FLUENT | 9 | August 31, 2011 01:33 |
turbulence at a porous jump (perforated plate) | andrew | FLUENT | 1 | May 8, 2004 09:51 |
