[ICEM] Mesh above curved surface causing problems |
January 3, 2021, 12:09 |
Athena
Rep Power: 5 |
Hello! I am struggling with improving the mesh above the pipe as shown in this diagram. What can I do to fix it? The pipe's curved surface in this diagram is in contact with the absorber plate and it is a rectangular surface.
What changes can I make for improvement? The pipe is surrounded by PCM, and in this diagram, the mesh is all curved in the PCM area as well. Is it alright to leave it like that or should I do some improvement? 5.jpg 1.jpg |
January 3, 2021, 14:30 |
Kira
Rep Power: 8 |
How did you block the internal cylinder, have you used an O-Grid? O-Grids can drastically improve element quality around circular objects. It would help to add an image of your blocking. |
icem cfd, icem mesh, icemcfd, meshing, meshing advice |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ANSYS Meshing] First layter thickness on mesh causing problems | Rik102 | ANSYS Meshing & Geometry | 0 | November 4, 2016 09:51 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 18:48 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
