Cant find mesh or geometry after scaling
Hello all,
A bit of a weird question maybe, but I have a model in which the units are in mm however I want to switch to m. I have made the 0.001 in x y z scaling for the geometry and mesh, but both times ran into a small problem which is that after making the geometry or mesh 1000 times smaller, I cannot see it anymore in the interface. I presume because it is so small, fit to window does not solve it, because it can either not find anything visible or says it has fit to window but I cannot see anyhting. Can anyone tell me what to do in order to see my mesh or geometry again after I have scaled it down 1000 times. P.S. If I export the model, I can view it in a mesh viewer and the scaling has indeed happend correctly, however I want to do some mesh checks or make some adjustments to the mesh, but this is not possible if I cannot see or interact with the mesh in ICEM after sclaing it down, Thanks for your help. Cheers, Jack |
Hello Jack,
Can you scale it down in parts perhaps? i.e. scale it down by a factor of 100 10 times and keep track of it after each time. |
Yes that helped, Thanks Kira
Hello Jack,
Glad I could help. ICEM can be pretty buggy sometimes. |
