[ICEM] Cant find mesh or geometry after scaling |
January 21, 2021, 12:34 |
Jack Tattersall
Rep Power: 6 |
Hello all,
A bit of a weird question maybe, but I have a model in which the units are in mm however I want to switch to m. I have made the 0.001 in x y z scaling for the geometry and mesh, but both times ran into a small problem which is that after making the geometry or mesh 1000 times smaller, I cannot see it anymore in the interface. I presume because it is so small, fit to window does not solve it, because it can either not find anything visible or says it has fit to window but I cannot see anyhting. Can anyone tell me what to do in order to see my mesh or geometry again after I have scaled it down 1000 times. P.S. If I export the model, I can view it in a mesh viewer and the scaling has indeed happend correctly, however I want to do some mesh checks or make some adjustments to the mesh, but this is not possible if I cannot see or interact with the mesh in ICEM after sclaing it down, Thanks for your help. Cheers, Jack |
January 21, 2021, 14:51 |
Kira
Rep Power: 8 |
Hello Jack,
Can you scale it down in parts perhaps? i.e. scale it down by a factor of 100 10 times and keep track of it after each time. |
January 22, 2021, 06:18 |
Jack Tattersall
Rep Power: 6 |
Yes that helped, Thanks Kira
January 22, 2021, 14:15 |
Kira
Rep Power: 8 |
Hello Jack,
Glad I could help. ICEM can be pretty buggy sometimes. |
icem, mesh, scale, scaling, visible |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[ICEM] Complex Geometry for Hex Mesh | smoerebroet | ANSYS Meshing & Geometry | 0 | January 9, 2015 15:21 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
