Valaki Valami
Rep Power: 4 ![]() |
Hi, I dont have a much experience with meshing. I meshed these two cylinders.
The bottom of the cylinder will be on constant temperature. There will be small parts on the top off smaller cylinder. That is not completed yet. I want to ask, is that a good way of meshing these cylinders for that simple experience? Is any way to improve it? There are some strange cross lines in section plane view, is that normal? Twocylindermeshing.jpg |
Erik
Rep Power: 20 ![]() |
Ignore the strange lines, I don't believe that is really part of the mesh, just graphical.
If this is just a solid, and not a fluid, that mesh is likely just fine. If it were fluid, I would have a smaller square or octagon in the middle, and mesh outward from there, so I didn't get those skewed elements in the 4 corners. But mesh quality for a solid is much less important, especially with just 1DOF (heat transfer). |
Display Modes | |
[ICEM] Meshing inclined cylinder with PBC tetra mesh ICEM | shashi_soman | ANSYS Meshing & Geometry | 0 | September 26, 2015 18:27 |
Meshing inclined cylinder with PBC tetra mesh ICEM | shashi_soman | Mesh Generation & Pre-Processing | 1 | September 26, 2015 18:05 |
[blockMesh] meshing a cylinder | Nico A. | OpenFOAM Meshing & Mesh Conversion | 0 | April 7, 2011 11:09 |
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder | nammari | OpenFOAM Meshing & Mesh Conversion | 5 | March 11, 2011 19:49 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
