October 22, 2016, 16:21 |
export cgns format mesh
Z.Ding
Rep Power: 9 |
I've got a problem when i try to export my 2D mesh in cgns format. The error is : The mesh file exporter failed during translation. Please send your data to your support provider. I've succeeded saving my mesh in msh format without any problem and i can't figure out where the error comes from. thanks |
February 16, 2021, 02:44 |
ANSYS MESHER fails to export 2d mesh
Rep Power: 5 |
Hello
I am experiencing same issue.Do you have any progress ? Best |
February 18, 2021, 11:57 |
Kira
Rep Power: 8 |
You can try opening the .msh file in ICEM and exporting it to CGNS format. I have done this before and haven't encountered a problem. |
February 18, 2021, 12:05 |
Rep Power: 5 |
I solved it. For 2d ,the problem is the intersection of x axis and mesh.That is , if you have negative coordinated node values at y axis mesher does not export and give error.Solution is simple.You should translate geometry upwards(+y direction). You may build geometry at origin;however ,during meshing some negative y coordinates created.
February 18, 2021, 13:47 |
#5 | |
Kira
Rep Power: 8 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 02:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
