[ANSYS Meshing] Sweep methods with inflation
Old   February 16, 2021, 01:12
Default Sweep methods with inflation
Dokeun, Hwang
dokeun is on a distinguished road
Hello
I’d tried to apply sweep method on a rocket nozzle with wedge shape.
I found an instruction for this from the inflation with sweeper section(244 page) in the user’s guide.
But it’s not quite clear for me. In this post, they recommend that one can use inflation then do sweep with manual option. But it didn’t work like that. The inflation is disabled as pic I attached.
Any suggestion to sweep with inflation on this would be appriciated.
Thank you.
From another guide it is said that 2D inflation should be applied. I’m doing this.
I think it is solved
Using 3D inflation set BL to the cylinder.
For the Nozzle part, I used 2D inflation on the interface face between cylinder and nozzle.
Then the boundary should be the wall edge of the interface face.
Left this for someone like me...
File Type: jpeg ECBAF2E4-7063-4A8F-A343-709A72153FD5.jpeg (172.0 KB, 6 views)
File Type: jpeg CAA4D0F4-13E3-4FD6-A30F-DCEAED795571.jpeg (166.6 KB, 6 views)
dokeun is offline   Reply With Quote
[ANSYS Meshing] Inflation layer of sweep mesh gives uneven first layer height clarice ANSYS Meshing & Geometry 0 September 25, 2020 13:58
[ANSYS Meshing] (Sweep + Inflation) Corner Mesh Quality Luiz ANSYS Meshing & Geometry 0 September 7, 2018 15:59
[ANSYS Meshing] Sweep Method and Inflation AS_Aero ANSYS Meshing & Geometry 4 July 26, 2018 12:35
[ANSYS Meshing] Axis-symmetric sweep with inflation and face matching starki ANSYS Meshing & Geometry 0 May 23, 2018 00:17
[ANSYS Meshing] inflation on the face other than source face of sweep meshing? jayash ANSYS Meshing & Geometry 0 April 16, 2014 04:11
