[ICEM] Interfaces between different 3 domains |
March 11, 2021, 02:46 |
Larissa C.Pinheiro
Rep Power: 11 |
I have been struggling some days now with an ICEM interface problem, ANY help would be much appreciated. I attached some self-explaining images of the geometry and the mesh. These images and questions are related to a reduced model of my real problem (three annular tubes inside a fluid domain). In the underlying model, I have 3 domains: two fluid domains and a solid domain (the tube). The external domain is fluid which encompasses an annular tube with some wall thickness. Fluid is also flowing through (inside) the tube. When a mesh the external fluid, the face against the tube should be an interface between it and both the tube and the inner fluid. However, while I have just one interface at the external fluid domain I got 2 faces touching it: one from the tube and another from the inner fluid. When I open this mesh in CFX-Pre it eighter tells me that I can only use one face from each domain to create a domain interface or put this face as a "default wall" (in case I don't assign a boundary condition to it). Any help would be much appreciated since I have tried many unsuccessful tricks. |
March 15, 2021, 15:06 |
Larissa C.Pinheiro
Rep Power: 11 |
My problem is actually that I have interfaces with different sizes. Anyone has ever faced such a problem?
ansys, cfx-pre, icem, interface defining |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
Discontinuity across interfaces | Nurzhan | CFX | 2 | March 11, 2015 01:59 |
Frozen Rotor 1:1 Mesh Connection | pharley | CFX | 5 | January 31, 2013 16:15 |
[ICEM] Using a ICEM mesh with multiple Domains in CFX without Domain Interfaces | ChristianF | ANSYS Meshing & Geometry | 0 | January 24, 2012 05:51 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
