March 17, 2021, 13:06 |
O-Grid meshing help
Rhys Powell
Rep Power: 5 |
Hi guys,
As part of my final year project at university, I'm modelling the flow around a cricket ball. This is my first time using ICEM and have generated the following mesh surrounding the ball. As you can see, at the seam position (marked in red) the mesh does not fall directly downwards with the actual geometry. In an ideal world, the elements on the seam would face directly downwards - to capture the seam edges. Any tips or tricks would be greatly appreciated. Thanks |
March 30, 2021, 06:38 |
Sebastian Engel
Rep Power: 20 |
You need to associate the edges respective edges to the respective curves.
What you see is the automatic association "face to nearest surface". Since you do not constrict an edge to follow a curve some faces span over a ridge. That will result in unaligned elements which are going to be patched as you can see in your screen shot. It seems you already have introduced splits left and right of the center to deal with the ridge. You now need to associate the circumferential edges to the respective curves (red and blue curves marked by you in the screen) There might be a few steps involved to further improve the boundary layer. You could introduce sublayers which have only the thickness of the ridges and map flush with it. That way you would not introduce sharp angle elements in the ridges proximity. However, try the simple approach first. p.s. i don't know the cricket-specific terminology to describe the ridge/ledge, i hope you understood |
March 30, 2021, 08:12 |
#3 | |
Rhys Powell
Rep Power: 5 |
Thanks for your reply, I've managed to fix the problem I was initially having. Please could elaborate on what you mean by subplayers? A sketch would be incredibly helpful, if that's not too much trouble. Thanks |
April 3, 2021, 15:56 |
Sebastian Engel
Rep Power: 20 |
I meant introducing sub-layers like this, a meridian cross-sectioon:
refined-ogrid.jpg You'd split the initial o-grid close to the spherical surface a few times to flush off the two lowest layer with the ridges. the third layer from the surface(black lines in the sketch), is optional. Anyhow. As you can see, the sketch draws a much more complex blocking. If your current mesh is good enough, i wouldn't suggest to go for a more complex structure. |
April 5, 2021, 04:21 |
#5 | |
Rhys Powell
Rep Power: 5 |
April 5, 2021, 14:27 |
Sebastian Engel
Rep Power: 20 |
Have a look into the geometry>curves menu. Here you'll find a feature which can extract the boundary curves from surfaces, and if necessary an other feature which creates iso-curves on surfaces.
And if this doesn't work, you might need to create curves by intersecting two surfaces---the ball's surface and a plane at the right position. |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[ICEM] ICEM Meshing Problem-2D Unstructured | Tariq Ahmed | ANSYS Meshing & Geometry | 0 | August 25, 2016 16:13 |
[Gmsh] Gmsh error while meshing a 3d grid? | tareqkh | OpenFOAM Meshing & Mesh Conversion | 0 | July 6, 2016 15:39 |
Need help with meshing 3D jet nozzle grid on ICEM | Jay1 | CFD Freelancers | 2 | March 21, 2016 05:55 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
