[ANSYS Meshing] Surface grid-extrusion technique?
Old   March 17, 2021, 16:46
Default Surface grid-extrusion technique?
menoufia
monali2015m is on a distinguished road
I have been looking for a sub-validation that is using a coupling approach -which is preferred in indoor natural ventilation, I tried to keep it simple since I am still learning so I settled with this case.
Cross-ventilation in a generic isolated building equipped with louvers:
Wind-tunnel experiments and CFD simulations
all the information that will allow me to re-create the case is available,
I created the geometry using grasshopper (so I can experiment with it later)
[IMG]file:///C:/Users/Mona's/Pictures/CFD.png[/IMG]
my issue is with the meshing the article kept referring to the surface grid-extrusion technique proposed by van Hooff and Blocken.
Coupled urban wind flow and indoor natural ventilation modeling on a high-resolution grid: A case study for the Amsterdam ArenA stadium
I read the previous article, still don't understand how it was done. and most cases that I found using the coupled approach keep referring to the Surface grid-extrusion technique.
so, please help (I am an architectural student so it was very hard and it took forever to reach this states, I'll be very grateful for any help )
monali2015m is offline   Reply With Quote
Old   September 21, 2022, 02:20
Eubo is on a distinguished road
Were you able to find an answer to your post? I have the same question!
Thanks for the help!
Eubo is offline   Reply With Quote
Old   September 21, 2022, 04:13
Gert-Jan
Gert-Jan will become famous soon enough
What is so special about this? This mesh can be generated in the Workbench mesher using the Method Sweep. Select a volume > Right-click to insert method > Select Sweep.
Note that this only works if the volume is sweepable. You can check this by:
Right-click on Mesh > Show > Sweepable Bodies.
If a volume is sweepable, then it will highlight Green.
Gert-Jan is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh generates not planar surface krzychu111 OpenFOAM Meshing & Mesh Conversion 2 April 23, 2020 17:38
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Surface Grid breakdown NavArchos Mesh Generation & Pre-Processing 1 January 27, 2013 17:22
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
