[ANSYS Meshing] How to mesh 3D FSI aortic valve problem? |
April 5, 2021, 02:06 |
Azadeh
Rep Power: 11 |
Hi there,
I am working on the 2-way FSI simulation of the 3D aortic valve. Since I am new to FSI simulation, I have a few questions regarding the meshing of it. First, what software should I use to mesh it? I was thinking of using the Fluent meshing tool. Not sure if it is the best option or maybe I need to work with ICEM. My second question is about the remeshing strategy that I need to implement. Since the valve leaflets are moving fast, I need to use dynamic meshing. However, I doubted if the available options in Fluent will help with this problem such as smoothing, layering, or remeshing. Do you guys have any suggestions on which strategy can help in this problem? I heard about using Immersed boundary method. But not sure, if it is going to help. Thanks in advance, |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
