[ANSYS Meshing] The mesh does not contain any shell elements |
April 5, 2021, 12:05 |
Na Be
I'm working in ACP pre, I did the mesh generation and this message appeared : '' The mesh does not contain any shell elements. This may be because the model is not compatible with section data providers'' even though the green checked mark appeared next to model (workbench) and also as I update dthe project on workbench a message showed saying "ACP input validation failure. There is no data contained in the input mesh file'' please help me. Thank you. |
acp (pre), ansys19, mesh, mesh file, shell mesh |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
Bad elements after generating unstructured volume mesh | max_beetle | Pointwise & Gridgen | 0 | October 24, 2017 01:52 |
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" | swparth | ANSYS Meshing & Geometry | 2 | June 27, 2017 07:12 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
