[Other] Assigning two faces separate NS on same surface
Old   April 6, 2021, 07:49
Default Assigning two faces separate NS on same surface
UchihaMadara is on a distinguished road
Hello all,
I am trying to assign NS to two faces on the same surface within Solidworks, but am not able to do so.
The blue region without the circle is to be plate-walls while the circle should be inlet.
If I do not define these two then there is an overlapping on the fluent import. Could anyone suggest how can I make the circle, as a separate surface, while the remaining as a separate clickable surface?
UchihaMadara is offline   Reply With Quote
named selections, overlapping, surfaces
[snappyHexMesh] No generation of layer onto zerothickness surface crubio.abujas OpenFOAM Meshing & Mesh Conversion 3 October 25, 2022 03:20
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
