[ANSYS Meshing] U-Tube
Old   April 7, 2021, 11:55
Default U-Tube
Nikolakis
Zerlox is on a distinguished road
I can't mesh the green part. Multizone keeps failing. Hexa dominant kinda worked, but am i supposed not to work with hexa dominant in cfd?
Zerlox is offline   Reply With Quote
Old   April 17, 2021, 12:10
Default notice
Nikolakis
I have sliced my part like this
Old   April 21, 2021, 08:27
kjetil is on a distinguished road
Have you tried to sweep it all the way? You might need the inner and outer to start and stop at the same location then, meaning the thinner outer part should be a separate body. But they can be connected through Shared topology.
kjetil is offline   Reply With Quote
Old   April 26, 2021, 08:44
Nikolakis
if i select explode part the meshing works but if i form a part with all the bodies errors appear. Any help?
Old   April 26, 2021, 08:51
It would help if you could explain the reasoning for dividing the geometry the way you have done. I would still recommend to sweep this. Is there a square hollow middle section in the tube?
You may want to share the geometry model as an attachment.
Old   April 29, 2021, 10:48
Nikolakis
I divided that for a better mesh. If i do not divide it i cannot sweep because sweeping doesn't allow inflation. I will post a picture with multizone, inflation and face meshing.
Old   April 29, 2021, 10:50
That is incorrect, you can use inflation with sweeping. Just select face and edge instead of body and face.
Old   April 29, 2021, 10:53
Nikolakis
Any recomendations?
Old   April 29, 2021, 14:57
This seems fine to me, but I don't see why there are several Face meshing and inflations, and still a Multizone. Wouldn't you say it is possible to use the large face you have here as the sweep surface? That would require 1) Sweep method, and 2) Inflation of this single face.
See also https://www.computationalfluiddynami...hing-in-ansys/
Defining Boundary Condition of Simulation of Shell and Tube Heat Exchanger ? miftahazhar FLUENT 0 June 26, 2019 10:34
Moving solid in a tube D2Net15 CFX 3 January 14, 2019 11:12
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
[OpenFOAM] Tube filter in Paraview werweisswas ParaView 0 December 10, 2012 06:18
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
