May 19, 2021, 10:09 |
BAD ANGLE on the edges
ANGELO
Rep Power: 5 |
I am meshing a geometry which consists of a cylinder with two plates on both sides of it separated by a gap(between the cylinder and each plate). The whole cylinder and the plates are then immersed in a fluid domain covering everything. I want to mesh the fluid domain around the cylinder, the gap and the plates.I have good quality of mesh except the angle around the gap. The problem is that the thickness of the gap is 1.12mm and when I put 10 nodes, I have bad angles and the elements start to overlap eachother at the edges. When I put 3 nodes or just 2, the angles are good. Its because the thickness too small, I cant add more nodes?? The area in which the angles are bad is highlighted in green in the image. Also I put the blocking. For the simulation: The gap and the cylinder are rotating at the same RPM to measure the friction factor Cf. I appreciate your help. Thank you, ANGELO |
May 19, 2021, 11:48 |
ANGELO
Rep Power: 5 |
I just realised that even if I reduce the number of nodes in the gap, the problem is still the same. I have bad elements between each two elements.
See in the figures the elements in red. Why the edges are not straight? Can anyone help me in this matter please? |
May 20, 2021, 11:39 |
ANGELO
Rep Power: 5 |
Can someone help me please concerning my problem?
The curves are not smooth maybe? I created these curves in design modeler to associate the edges. |
May 20, 2021, 15:47 |
Sebastian Engel
Rep Power: 20 |
Hi Angelo,
it seems the curves are not coincident with the surfaces. They seem to be ever so slightly next to them. Only the point (in the first image of the second post) seems to be exactly in the surface. There is one thing i would do; try to decrease to topology tolerance, and triangulation tolerance to a much finer value. Maybe it is only a discreetization problem of the geometry. Maybe the curves created in the design modeller where not mathematically exact. Can you try to recreate them in ICEM? Best, Sebastian |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
