[ANSYS Meshing] ANSYS: Problem with Meshing a cylinder |
June 6, 2021, 02:52 |
Betelhiem
Rep Power: 4 |
Hello there,
I was trying to solve a species transport in a simple circular solid. I made the geometry using SpaceClaim and also meshed it. I created name selections to help me in the boundary conditions, but here is the problem, I created an inlet on the side and the outlet on the bottom of the cylinder. But after I import it to a fluent solver the inlet disappeared, I will attach the pic. I think it is because the inlet is surface? I don't know. Can you please help? I really need the inlet in the boundary conditions. Thank you! |
June 6, 2021, 02:54 |
Betelhiem
Rep Power: 4 |
Here is what it looks like in the fluent.
June 8, 2021, 02:29 |
Rep Power: 17 |
Seems your outlet is a surface (B), not a part of the main cylinder body. You would then have to extrude and join/boolean those two together to have a proper single body.
Ansys Fluent Meshing Problem: Conflicting zone names | SimonWjp | FLUENT | 0 | November 8, 2016 10:38 |
[ANSYS Meshing] Ansys meshing problem | behzad-cfd | ANSYS Meshing & Geometry | 0 | May 5, 2016 17:44 |
[ANSYS Meshing] Cylinder meshing problem | quiet592 | ANSYS Meshing & Geometry | 1 | December 13, 2011 11:21 |
Meshing problem with ansys default mesher | wh88 | ANSYS | 5 | October 5, 2011 16:27 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
