[TurboGrid] problem with topology
Old   February 17, 2019, 15:53
Unhappy problem with topology
Dagmara
verinna is on a distinguished road
i'm making axial turbine (blade model generated by BladeGen) in TurboGrid. I made mesh and want to improve quality of elements, using ATM Optimized Topology (which should be in topology definition) but I don't have this option. When I opened Topology Definition, I have only ATM Topology Method to choose. Where can I find ATM Topology Placement?
I thought that I must turn on something in option so I clicked on "enable advanced features" in Edit -> Option but it didn't help.
screen from my program
verinna is offline   Reply With Quote
Old   July 24, 2020, 21:50
Default Topology Definition (Placement)
Angel Reyes
Alex84pg is on a distinguished road
Good eveninig, I have got the same issue, I can not find topology definition in turbogrid, Somebody knows where is it?
Thanks and good night!
Alex84pg is offline   Reply With Quote
Old   July 29, 2020, 08:22
Henrique Stel
Stel is on a distinguished road
I'm not sure about that but I suspect that once you already got your geometry loaded and performed a given topology calculation, TurboGrid disables some topology methods. Something you could try (I've tested here right now and it worked): open a new, clean Turbogrid window first, enable the Advanced and Beta feature boxes in the Edit>Options window, go to Topology, choose the one you want beforehand, and then load the geometry.
Let us know if that worked. GL.
Stel is offline   Reply With Quote
Old   July 12, 2021, 07:28
Feng
wind_ is on a distinguished road
Its good suggestion
wind_ is offline   Reply With Quote
[ICEM] ICEM CFD topology problem (airfoil) metaliat93 ANSYS Meshing & Geometry 0 July 8, 2017 13:35
Adjoint Convergence Problem FlyBob91 OpenFOAM Running, Solving & CFD 1 April 27, 2017 05:02
Heat Transfert, mixing problem Wazdq CFX 8 November 7, 2016 05:44
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
