February 17, 2019, 15:53 |
problem with topology
Dagmara
i'm making axial turbine (blade model generated by BladeGen) in TurboGrid. I made mesh and want to improve quality of elements, using ATM Optimized Topology (which should be in topology definition) but I don't have this option. When I opened Topology Definition, I have only ATM Topology Method to choose. Where can I find ATM Topology Placement? I thought that I must turn on something in option so I clicked on "enable advanced features" in Edit -> Option but it didn't help. screen from my program |
July 24, 2020, 21:50 |
Topology Definition (Placement)
Angel Reyes
Good eveninig, I have got the same issue, I can not find topology definition in turbogrid, Somebody knows where is it?
Thanks and good night! |
July 29, 2020, 08:22 |
Henrique Stel
Rep Power: 17 |
I'm not sure about that but I suspect that once you already got your geometry loaded and performed a given topology calculation, TurboGrid disables some topology methods. Something you could try (I've tested here right now and it worked): open a new, clean Turbogrid window first, enable the Advanced and Beta feature boxes in the Edit>Options window, go to Topology, choose the one you want beforehand, and then load the geometry.
Let us know if that worked. GL. |
July 12, 2021, 07:28 |
#4 | |
Feng
Rep Power: 9 |
[ICEM] ICEM CFD topology problem (airfoil) | metaliat93 | ANSYS Meshing & Geometry | 0 | July 8, 2017 13:35 |
Adjoint Convergence Problem | FlyBob91 | OpenFOAM Running, Solving & CFD | 1 | April 27, 2017 05:02 |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
