[ANSYS Meshing] Actuator disk for fan boundary condition in Fluent
Old   September 22, 2021, 16:22
Default Actuator disk for fan boundary condition in Fluent
Adithya
Adithya_11 is on a distinguished road
Hello
I am creating a mesh for an aircraft in ANSYS Meshing for simulation in Fluent. I am simulating only half the aircraft and will apply symmetry condition.
I need to incorporate an actuator disk using the fan boundary condition in Fluent to simulate a propeller. This study will only have axial flow through the disk and no tangential flow. Hence, my symmetry condition is explained.
How do I create the mesh and the body for the fan?
Can I include the complete disk in ANSYS and then use some method to cut it in half with my domain body?
Should it be a surface? Or should I boolean subtract it out of the fluid domain?
Adithya_11 is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
How to transfer boundary condition from Openfoam to fluent sachinlb OpenFOAM Post-Processing 1 January 6, 2012 01:41
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
