[ANSYS Meshing] Fluent Meshing Multi-Region Domain gives interior walls when importing to OpenFOAM
Old   October 8, 2021, 07:11
Default Fluent Meshing Multi-Region Domain gives interior walls when importing to OpenFOAM
N/A
twnspl is on a distinguished road
I am doing a project in which I have to compare ANSYS and OpenFOAM simulation results with the same mesh. I am simulating flow over a wing in which I have used a large domain which is far away from the wing and smaller refinement region. I made both the domain and the refinement zone using design modeller. Both are solids which are combined into a part to create conformal meshes. The problem arises when I import this mesh to OpenFOAM using the fluent to foam mesh converter. The inner refinement region appears as a wall in OpenFOAM's boundary file which is causing issues as I want these patches to not be boundary since this affects the results. I have attached the image of the whole domain and the "wall" to this post. Is there any way I can rectify this either in ANSYS or OpenFOAM ? I would really appreciate your help. Thank You !
twnspl is offline   Reply With Quote
fluent, meshing, openfoam
ANSYS fluent and OpenFoAM comparison gentodin Main CFD Forum 6 February 26, 2021 03:58
[ANSYS Meshing] asking about multi domain conformal mesh in Ansys Meshing 17.2 teguhtf ANSYS Meshing & Geometry 0 March 27, 2020 17:45
[ANSYS Meshing] How to meshing multi small tubes in a large domain ?? Jamessmp23 ANSYS Meshing & Geometry 2 October 27, 2018 22:58
Transforming Multi objects in Fluent to openfoam??? umdj@keri.re.kr OpenFOAM 0 June 21, 2016 05:05
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
