November 19, 2021, 08:12 |
Negative volume check
Rep Power: 5 |
I have generated a multiblock, 3D C-grid mesh on ICEM and am trying to use it on a custom solver that requires a plot3D mesh format. However, the code tells me to check for negative volume. I tried to do this check on both ICEM and Pointwise and the results are attached. I wanted to know why Pointwise shows negative values while ICEM shows positive. The mesh used was exported from Pointwise so it makes sense that the code would give me the error. Thanks |
Problem with blockMesh | cshsgy | OpenFOAM Pre-Processing | 2 | October 2, 2017 11:46 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
