[ANSYS Meshing] 3D mesh cells are not attached to the blade |
May 14, 2022, 14:34 |
Sakun
Rep Power: 6 |
I am meshing naca65 3D blade in ICEM and as shown in the 1 and 2 pictures, mesh cells at the trailling edge are not attached with the blade wall. i did association many time and still problem is same. any help is highly appriciated |
May 31, 2022, 02:20 |
Chrowale
Rep Power: 4 |
Disassociate the white edge on the TE and then associate it again with the TE curve. Hopefully it works!
airfoil 3d, ansys icem, icem |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[mesh manipulation] how should we remove the Concave cells from the mesh? | s.m | OpenFOAM Meshing & Mesh Conversion | 20 | March 5, 2020 16:35 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
