[ICEM] Unstructured meshing of a 3D multi element wing
Old   July 7, 2022, 15:33
Question Unstructured meshing of a 3D multi element wing
Rohan Sunil
rsunil is on a distinguished road
Hello everybody,
I have been looking for solutions on generating a tetra/prism mesh of a 3D multi element wing or even multi zone meshing but I could not find ones which could solve exactly my problem.
Tetra/Prism approach
When I generate the mesh for the multi element wing using the tetra/prism approach, the overall cell quality reduces a lot after generating prism layers mainly due to the trailing edges (square blunt edges). In order to accommodate better quality cells at the trailing edge, my mesh size increases to around 20 million or more. Like Simon suggested in other posts, I tried making internal wall baffles at the trailing edges of the elements, which helps so much by reducing the cell count but still ends up with very poor quality cells (~0) at the end of the surface and the airfoil tips.
So I gave up on this approach and went for the multi zone strategy since it proved to generate high quality boundary layer meshes.
Multizone approach
For this approach I recreated my geometry to have square tip trailing edges in order to help with blocking. It was all fine when creating the 2D surface blocking. But when I apply the 2D to 3D multizone fill, it throws an error saying that it did not create volume cells. All the elements except the flap are in contact with the symmetry plane. I read in an older post that if they are not in contact with all the faces in the domain then it won't be able to create the mesh as desired.
At this stage I am not sure what to do, I would prefer to stick with any other method except for a structured mesh.
I would be very grateful for your suggestions and advice
Thank you for your time in advance
rsunil is offline   Reply With Quote
Old   July 9, 2022, 08:01
Chrowale
mluckyw is on a distinguished road
From my personal experiences, I given up on doing unstructured with ICEM. I only use it if I need a structured blocking. I suggest giving ANSYS mesher or Fluent meshing a try.
Unstructured in ICEM giving me a lot of problem that occurs because of the geometry is not water tight? (I think it need to create a topology again in ICEM) even though, it is water tight if I opened it Spaceclaim.
mluckyw is offline   Reply With Quote
3d unstructured, high lift, icem, multi element
gmshToFoam unhandled element 1 at line... warning Minecre57 OpenFOAM Pre-Processing 0 November 1, 2020 12:54
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 11:14
[DesignModeler] Meshing a Delta Wing ANSYS CFX - Cannot get inflation around the tip of the wing? Jack121 ANSYS Meshing & Geometry 0 April 12, 2019 10:08
[ANSYS Meshing] Meshing fluid around sharp edges of a 3D insect wing. minglis ANSYS Meshing & Geometry 1 February 2, 2017 09:14
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 11:29
