Technical issue with GUI
2 Attachment(s)
Hello, I just installed student-licensed ANSYS.
When I start ICEM CFD, the 3D workspace is stuck at green screen. Usually I am supposed to see XYZ axis on the bottom right corner and blue gradient background(default option). It does not seem like a license problem because I do not get any error messages. But everything works just fine. I can still create points and lines, etc. I just connot see anything. Thank you in advace for your help! just in case, I'll write my laptop spec. CPU: Ryzen 9 5900HX with Radeon Graphics GPU1: AMD Radeon(TM) Graphics GPU2: Nvidia GeForce RTX3070 Laptop GPU |
Have you tried to reseting to default settings? Settings -> Reset
For the XYZ axes, try Settings -> Display -> Show XYZ Axes Aso, you can try Settings -> Background style and change the green color for white or black, which personally, I prefer to work with. |
