[ICEM] icem mesh miss a line
Old   August 30, 2022, 23:22
Default icem mesh miss a line
cofan is on a distinguished road
Hi, I'm cofan.
I changed my model, The parts that went wrong were unchanged. Now ICEM seems to miss a line. I know the angle is too sharp, but the mesh can be generated normally before modifying the model.
correct mesh
wrong mesh
miss mesh line
I don't know the reason.
cofan is offline   Reply With Quote
Old   September 1, 2022, 03:24
Gert-Jan
Gert-Jan will become famous soon enough
You can create curves yourself in ICEM. Use the surfaces as a start:
Geometry -> Create/Modify Curve -> Extract Curves from Surface.
There select one of the surfaces and the missing curve will be created.
If you want to have more control over the mesh in your sharp angle, then follow this thread:
Mesh Is Not Following Trailing Edge Curve Correctly
Gert-Jan is offline   Reply With Quote
Old   September 1, 2022, 03:47
Thank you, Gert-Jan.
Curve exist. What is missing is the line of Mesh. I tried to remove this curve, and recreate it. but the mesh doesn't seem to know this curve.
Old   September 1, 2022, 04:23
Gert-Jan
Define a thin cut. That usually works.
Press F1 for help with examples.
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
