September 8, 2022, 02:06 |
Tom-Robin Teschner
Rep Power: 16 |
The short answer is, you can't. You can get closer with a hexcore volume mesh and then adding inflation layers, but the image you are showing requires a structured mesh generator like icem-cfd, pointwise, etc. If you have access to these mesh generators, look at the structured mesh tutorials that come with the software, this should get you started.
Learn to write CFD solvers at cfd.university |
September 13, 2022, 04:39 |
bigfoot
Rep Power: 17 |
You could use ANSYS design modeler to create a cube and ANSYS Meshing with a mapped face and choose one of the structured meshers. Inflation layers will indeed not work but you can make the mesh size sensitive to the distance from nodes and edges.
For such a geometry it might be better to use one of the tools already mentioned, or gmsh if you do not have a license for the commercial meshers. |
ansys fluent, mesh 3d |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Exporting Mesh from Pointwise to ANSYS FLUENT | mrswordf1sh | Pointwise & Gridgen | 14 | September 6, 2017 10:23 |
Ansys Fluent Mesh to be Used in Mechanical Thermal System | jjlt | ANSYS | 0 | January 26, 2017 01:50 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
