[Other] Change minimum size in sketch SpaceClaim |
September 15, 2022, 10:00 |
Rodrigo Villarreal
Rep Power: 9 |
Hello everybody,
I'm making a very simple wedge like geometry in SpaceClaim but when I try to do a very short line (about 0.01 mm) it gives me the warning: "One or more of the created curves was below the minimum size for use with sketch constraints" And doesn't draw the line. Does anyone know how to change that minimum size for sketching, or if it is even possible to draw lines that short? Thank you |
September 16, 2022, 07:33 |
Gert-Jan
Rep Power: 27 |
A work around is to create a geometry 1000 times larger, mesh it and then scale it back in the solver. At least in CFX and Fluent this is possible.
September 16, 2022, 21:52 |
Rodrigo Villarreal
Rep Power: 9 |
Thanks, I'll try it.
ansys, sketch in ansys, spaceclaim |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
minimum grid size in gas flow simulation in cylinder | YHY | CONVERGE | 1 | October 30, 2017 06:49 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Minimum possible element size | Tscar | Main CFD Forum | 3 | February 12, 2016 13:50 |
minimum mesh size for CFX | julien | CFX | 1 | January 12, 2006 06:37 |
