[ANSYS Meshing] Inflation problem
Old   September 22, 2022, 09:49
Default Inflation problem
Nikolakis
Zerlox is on a distinguished road
Hello i am trying to mesh a tube with a vortex generator. I thought to use sweep near the inlet and the outlet and tetra patch conforming in the middle part near the vortex generator. But the inflation doesn't really work in the middle part any workarounds? Thank you
Zerlox is offline   Reply With Quote
Old   September 23, 2022, 05:40
siw
Stuart
siw will become famous soon enough
I assume you set a first layer height in the Inflation option. What happens if you use Smooth Transition?
You have very large element volume difference from the final inflation later and the volume mesh. Good practice is to have a volume change of less than 20%. Also, reduce the volume element size and see what that does.
siw is offline   Reply With Quote
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 08:14
[ICEM] Hexa Meshing Inflation Problem avinashcfd ANSYS Meshing & Geometry 1 June 13, 2018 11:56
[ANSYS Meshing] Inflation layers problem frossi ANSYS Meshing & Geometry 0 July 2, 2016 19:41
[ANSYS Meshing] Problem when I want to make inflation in 2D Naca Profile sansaiga ANSYS Meshing & Geometry 0 February 17, 2016 09:01
