September 22, 2022, 08:49 |
Inflation problem
Nikolakis
Rep Power: 5 |
Hello i am trying to mesh a tube with a vortex generator. I thought to use sweep near the inlet and the outlet and tetra patch conforming in the middle part near the vortex generator. But the inflation doesn't really work in the middle part any workarounds? Thank you
September 23, 2022, 04:40 |
Stuart
Rep Power: 25 |
I assume you set a first layer height in the Inflation option. What happens if you use Smooth Transition?
You have very large element volume difference from the final inflation later and the volume mesh. Good practice is to have a volume change of less than 20%. Also, reduce the volume element size and see what that does. |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 13:52 |
Problem diverges when exhaust valve opens | swerner0711 | AVL FIRE | 0 | September 21, 2018 07:14 |
[ICEM] Hexa Meshing Inflation Problem | avinashcfd | ANSYS Meshing & Geometry | 1 | June 13, 2018 10:56 |
[ANSYS Meshing] Inflation layers problem | frossi | ANSYS Meshing & Geometry | 0 | July 2, 2016 18:41 |
[ANSYS Meshing] Problem when I want to make inflation in 2D Naca Profile | sansaiga | ANSYS Meshing & Geometry | 0 | February 17, 2016 08:01 |
