[ICEM] O-Grid for T-Joint at a tube in tube heat exchanger |
Jorge Rivera
Rep Power: 6 ![]() |
Dear CFD-Online Community,
I have been working on a hexa blocking mesh in ICEM. I have tried for so long to achieve a proper Ogrid at the T-Joint of a tube in tube heat exchanger. My problem is that when I try to generate the Ogrid, the blocks that belong to the inner tube of the heat exchanger do not allow the proper generation of the Ogrid. Do you have any strategy to tackle down this issue? I would be very grateful for any comments or suggestions. |
#2 | |
For the pipe/tube that's going in X direction -> while trying to generate the inner O grid select the main block and the parallel faces too. |
#3 | |
Jorge Rivera
thank you so much for your reply. Your piece of advice helped me a lot. I just wanted to check with you, if I understood you right. I generated the O-Grid as seen on the first screenshot. I tried the same strategy for the connection between the heat exchangers (please see the second screenshot), but then the elements show a negative orthogonal quality. Do you have any recommendations? Thank you so much once again for your support. |
Chrowale
Rep Power: 5 ![]() |
Okay, I don't know if it solved or not but the curiosity bit me first
![]() So You need a combined O-grid in the blocking, not separated O-grid. The selection are like the attachment below, it's a bit hard to visualize. PM me your email if you want the file for this mesh. Edit: Basically, select all the blocks and select the face where you don't want any O-grid generated ie, opening, inlet, outlet |
#5 | |
Jorge Rivera
thank you so much for your suggestion I will try it out. In the meantime, I have send you my email address in a PM. |
hexa block, ogrid in volume, t-joint |
Display Modes | |
Fluent Heat exchanger model | gimson | FLUENT | 0 | May 10, 2021 05:30 |
Concentric tube heat exchanger not showing temperature variations | B_R_Khan | FLUENT | 0 | December 31, 2020 15:33 |
shell and tube heat exchanger... | ganesh chakravarthi | CFX | 3 | July 6, 2015 19:44 |
Analysis of shell and tube heat exchanger in Ansys | Dena | FLUENT | 0 | June 12, 2015 14:39 |
concentric tube heat exchanger | satya | CFX | 4 | January 16, 2002 10:06 |
