Enveloping an irregular solid with a certain thickness
Hi. I'm new here.
I would like to ask help regarding this geometry that I initially prepared: https://i.ibb.co/Npbkd4y/111.png I wanted to make an enclosure for this geometry in SpaceClaim, but what I see from guides are simple box, cylinder, and sphere enclosures. What I wanted to happen is to make another solid that would enclose the entire thing that is about 5 millimeters thick at all sides. That way, when I suppress the solid I have prepared I would have a hollow solid that is similar to this thing that I prepared that is 5mm thick. How can I achieve this? Thank you! |
Try the shell feature.
Another way to do this:
You could make another copy of the solid and scale it until it reaches the desired distance from the original body. Detach all of the solids to turn it into surfaces and make two solid that has a gap in the middle for the original body, then combine those two bodies. |
I did try to use the shell feature, but an error keeps on popping up: "Cannot shell body, as it already contains an inner shell." Could you point out what I did wrong here? |
I actually had this idea initially, then I started to think how can I make sure that the thickness of the resulting hollow solid would be 5mm. |
Then now I have this issue that I cannot separate the prepared shell from the original body. Any ideas what should I do here? |
My issue now is how to separate this shell generated from the solid. It just shows as a single solid in the structure pane (actually this is the reason why I didn't even realize that I already made the shell. There's nothing 'new' appearing in the structure pane). EDIT: This is what I mean: https://i.ibb.co/M8fYj6K/222.png I managed to see that there is a shell by deleting one of the shell's faces. My problem is I cannot separate this generated shell from the solid formed. |
So, in your feature tree I can see a solid and a surface body.
But you only did get the surface body due to deleting of one face, correct? If you would have not deleted that face, you only had one solid? |
Great to hear! Yes, I tried it out yesterday and also saw that it goes inwards. I tried to enter a negative number but it didn't work haha [emoji23][emoji28]
