Removing the prism layer from a hexcore mesh created in ANSYS Fluent Watertight Mesh
4 Attachment(s)
Hi there,
I am trying to create a hexahedral hex-core mesh for the following nozzle geometry for a compressible flow study,(pictures attached below). The inputs of the mesh are as follows : Local face size ( for nozzle walls and domain boundaries ): 0.5mm Surface mesh size: Min. size: 0.5mm, Max. size: 4mm Boundary Layer: 20 layers with a growth ratio of 1.1 on walls The issue I'm currently facing is the presence of a triangular prism layer on the boundary layer. I'm trying to remove that and make it a hex element as well. Please advise on how I can resolve this issue. Thank You |
